1993 Pontiac Grand Am Sluggish upon going up hills and merg
1993 PONTIAC GRAND AM
98,000 MILES • 6 CYL • FWD • AUTOMATIC
ANDREW GILLOON
My Grand AM GT is having troulble accelerating, ups hill and inclines as well as when merging onto a interstate. My mechanic ran a dianostic and it came back a bad EGR valve. Installed new and still had same problem. Then installed new fuel filter with no luck. He put tested the fuel pump and thats fine. My mechanic is out of ideas. Can you give me a hand with this.
Thanks
Aug 7, 2008 at 6:21 AM
KLSHIEL
  • 163 POSTS
Try cleaning the intake, cleaning injectors and changing PCV (if has them), and check the air filter. These are all things that are cheap should be done during tune up and can effect how the engine runs.
Aug 7, 2008 at 6:53 AM
