1993 Pontiac Grand Am horn
1993 PONTIAC GRAND AM
BRAULIO707
Electrical problem
1993 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic
my horn doesnt work what do i do
Aug 10, 2009 at 8:11 AM
JDL
  • 16,098 POSTS
Hello, I think usually the problem is in the steering column, I always check everything else, first. Check 15 amp horn fuse in the fuse box, also check that the circuit is hot, use a test lite. There should be a horn relay in the convenience center, probably located under the dash, don't have exact location. You could do some testing at the relay.
Also, you could take the connector loose from the horn, use a jumper wire from the positive battery post to horn connector, dark green wire to the horn, use inline fuse on the jumper, remember that is a live wire, the horn should honk.
Aug 10, 2009 at 8:28 AM
