1993 Pontiac Grand Am Check engine oil
1993 PONTIAC GRAND AM
110,000 MILES • 6 CYL • FWD • AUTOMATIC
CALLSIGN
  • 7 POSTS
My check engine oil lite comes on briefly every so often, I think it is a connection at the engine but where do I find what to look for
Dec 10, 2009 at 9:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
is your engine oil at full level? if it is then it may be a weak oil pump causing this or a fualty oil sending unit. sending unit should be near oil filter housing.
Dec 18, 2009 at 8:29 AM
CALLSIGN
  • 7 POSTS
Thank you, I will look there and yes the oil level is full
Dec 18, 2009 at 9:51 AM
