1993 Pontiac Grand Am battery
SINCITIES1ANGEL
Engine Performance problem
1993 Pontiac Grand Am 4 cyl Two Wheel Drive Automatic 180 K miles
My husband has a 1993 Grand Am, he retired over a year ago and does not drive it at all...3 months ago he tried to start it and it would not turn over. We had it towed to a shop, they charged it and it started right up....he neglected to go out and start it up on a regular basis...and it won't start again....so we replaced the battery and it still won't turn over....it cranks but will not turn over....
Feb 20, 2008 at 2:56 PM
  • 75,988 POSTS
Try this spray carb cleaner into the throttle body and see what happens-if it starts and dies out-start by checking fuel pressure and injection pulses.
Feb 20, 2008 at 3:08 PM
SINCITIES1ANGEL
[quote:787a8d1b54="rasmataz"]Try this spray carb cleaner into the throttle body and see what happens-if it starts and dies out-start by checking fuel pressure and injection pulses.[/quote:787a8d1b54]
did that, nothing happened. my husband was wondering what the possibility of the fuelpump being loose inside is?
Feb 21, 2008 at 4:53 AM
  • 75,988 POSTS
Using the carb cleaner should make it start and die out if the ignition system is working properly. Disconnect a sparkplug wire and ground it to the engine while helper crank engine over-do you have spark?
Feb 21, 2008 at 5:55 AM
SINCITIES1ANGEL
did it and changed fuses, got it started. Driving it for a while to see if it holds a charge...
Feb 21, 2008 at 6:29 AM
JSCZYNSKI
  • 48 POSTS
you might have stale fuel as well. :D
Feb 28, 2008 at 4:08 AM
