HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Am
Engine
Symptoms
Stall While Driving
SPONSORED LINKS
1992 Pontiac Grand Am stalling
BIGWRENCH46
MEMBER
1992 PONTIAC GRAND AM
Engine Performance problem
1992 Pontiac Grand Am 4 cyl Two Wheel Drive Automatic
i replaced the engine in car and it operates fine but when I put it in gear either drive or reverse it stalls.
Monday, May 11th, 2009 AT 6:44 PM
BMRFIXIT
MECHANIC
Check and adjust tranny fluid
check for engine codes
check and clean idle air control valve
check for any vacuum leaks
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
SPONSORED LINKS
Monday, May 11th, 2009 AT 8:58 PM
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
1992 Pontiac Grand Am Car Stalls Out After Running...
Hello I Have A Strange Issue With This Grand Am. You Can Drive The Car For About 20 To 30 Min And Then It Starts Running Rough And Dies. It...
Asked by
russinminneapolis
1 ANSWER
1992
PONTIAC GRAND AM
VIDEO
Is it Safe to Drive Check Engine Light?
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
1992 Pontiac Grand Am Engine Stalling
I Have A 92 Grand Am Gt 3.3l V6 With About 290,000 Kilometers Now My Problem Is When I've Driven The Car To Three Different Places On The...
Asked by
Mushroomtip204
1 ANSWER
1992
PONTIAC GRAND AM
1992 Pontiac Grand Am Stalling And Revving
I Am Writing From Canada Yet We Are Having Quite A Mild Winter This Year. It Is Only -10 Degrees Farenheigt Tonight. Im Not Sure If This Is...
Asked by
katjafallingstar
1992
PONTIAC GRAND AM
1992 Pontiac Grand Am Stalling As Slowing Down At Red...
My Car Has Be Occasionally Stalling As You Slow Coming Up To A Red Light. It Is Like The Transmission Is Not Gearing Down. Tonight, It...
Asked by
cbaul1
1 ANSWER
1992
PONTIAC GRAND AM
1992 Pontiac Grand Am Stalling Dies When Hot
The Car Starts When Cold, But When Hot Starts To Misfire Heavily, Then Dies. Tried Two Different Modules, Did Not Solve The Problem. Once...
Asked by
mythology2112
1 ANSWER
1992
PONTIAC GRAND AM
VIEW MORE
SPONSORED LINKS
How to Clear a Check Engine?
Code Read Retrieval/Clear Honda
How to Read Codes
Online car repair manuals
