1992 Pontiac Grand Am brand new starter wont turn motor ove
JOSHUAJFRY
MEMBER
1992 PONTIAC GRAND AM
Engine Mechanical problem
1992 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 120k miles
replaced starter and there is an audible clicking and ther alternator moves slightly but engine does not turn over
Tuesday, October 6th, 2009 AT 5:12 PM
CRZYDRVR
MEMBER
Check other components such as a/c compressor, water pump etc to make sure they will rotate. You should take off the serpintine belt to do this. Also check your connections at the battery and the starter for tightness and make sure the connections are clean.
