When attempting to start I can see gas pumping out of the injector. I have to poor gas into it to get it to start. I have to pump the gas pedal to keep it running. I have checked for vacum leaks, replaced the brain, fuel pump fuel filter, injector, fuel pressure regulator, temp. switch, oxygen sencor, map sencor, throttle postion sencor, crank cencor, and the fuel injector. There is no codes per code scanner. If any suggestions please let me know.
Mar 17, 2009 at 8:29 AM
