1991 Pontiac Grand Am replace fuel pressure regulator
150,000 MILES • 4 CYL • FWD • AUTOMATIC
PILEDRIVER
I need to know how to replace the fuel pressure regulator on the throdle body type fuel injection system in this old pontiac
Jun 16, 2009 at 12:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Relieve fuel pressure.
Disconnect pressure regulator-to-fuel rail hose. Remove fuel rail.
Remove pressure regulator retaining bolts. Remove pressure regulator from fuel rail. Remove pressure regulator retainer and seal from fuel rail.
To install, reverse removal procedures. Always replace the "O" rings. Lubricate fuel rail seal with oil and install in regulator.
Jun 16, 2009 at 12:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Sorry, my mistake. That was for wrong fuel system..here is the correct procedures for your TBI system. You will have to remove the throttle body cover, the regulator and body cover are serviced together only.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_547.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_138.jpg
Jun 16, 2009 at 12:46 PM
