When trying to start this 2.5 engine, i can mist starting fluid over the throttle-body, and it will runand removing the fluid it dies. We removed the wires from the injector in the throttle-body,used a test light to check for voltage, and it,s there. There is a red wire,and a blue wire. Using a testlight, I hooked it,s negative on the neg. post of the battery and stuck the probe in the end of the red wire,and cranked the engine. It had voltage. Then, I clamped the negative on the test-light on the pos. side of the bat. and there was no light on the blue wire. Could it be a computer problem? All fuses are good. It,s a 4 Tech if that means anything.
Nov 6, 2010 at 2:50 PM
