1991 Pontiac Grand Am Engine will not run
HOGIE09
  • 1991 PONTIAC GRAND AM
  • 4 CYL
  • 154,380 MILES
When trying to start this 2.5 engine, I can mist starting fluid over the throttle-body, and it will runand removing the fluid it dies. We removed the wires from the injector in the throttle-body, used a test light to check for voltage, and it, s there. There is a red wire, and a blue wire. Using a testlight, I hooked it, s negative on the neg. Post of the battery and stuck the probe in the end of the red wire, and cranked the engine. It had voltage. Then, I clamped the negative on the test-light on the pos. Side of the bat. And there was no light on the blue wire. Could it be a computer problem? All fuses are good. It, s a 4 Tech if that means anything.
Saturday, November 6th, 2010 AT 9:50 PM
SERVICE WRITER
  • 9,123 POSTS
Maybe I am not reading correct, but if you supply starting fluid it runs, correct?
Did you check fuel pressure. It Must be in spec. What is the pressure at?
Sunday, November 7th, 2010 AT 3:39 AM
KHLOW2008
  • 41,814 POSTS
Hi hogie09,
Thank you for the donation.
Test indicates the PCM is not grounding the fuel injector circuit. Check for continuity between the injector Blue wire and PCM terminal # W1. If continuity is available, the PCM is most likely faulty.
Sunday, November 7th, 2010 AT 3:41 AM
SERVICE WRITER
  • 9,123 POSTS
Thanks Low!
Sunday, November 7th, 2010 AT 8:26 AM
