1991 Pontiac Grand Am Engine keeps stalling
RAYMOND555
Engine Performance problem
1991 Pontiac Grand Am 6 cyl Two Wheel Drive Automatic
My pontiac will start up like normal, run for about six minutes, then start to stall, it will run very ruff, then it will stall. I can start it 3 or 4 times it will do the same thing then it will not start at all. It will just keep cranking over. I took off the air cleaner cranked it over and it seams that there is no gas in the carb. If i wait for three or four hours it will start up and do the same thing then stall. when the car is running i can see gas in the carb.
Dec 7, 2008 at 8:47 AM
  • 75,988 POSTS
Check the fuel pressure to rule out the fuel pump-if its okay report back
Dec 7, 2008 at 9:54 AM
