1991 Pontiac Grand Am Clutch
1991 PONTIAC GRAND AM
188,000 MILES • 4 CYL • FWD • MANUAL
CILLA07
I have 91 Pontiac Grand Am 5 speed. It will go into 1,2,3 and 4th no problem but will not go into 5th or reverse. It feels like something is blocking it from shifting. What could be the problem?
Aug 22, 2010 at 11:38 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the 5th gear and Reverse gear share the same shaft in the transmission, this could be bent or the linkage could also be bent. can you shift into either of these gears if you turn the motor off?
Aug 22, 2010 at 11:41 AM
CILLA07
No i can not shift into either gear when its off
Aug 23, 2010 at 9:56 AM
