symptoms: after running car for 25, 30, miles,the car stalls at any stop sign, or slowing down. will start right
back up, but will stall ones in gear. put in park, will start up until you put in gear.after about 5 min,will go into gear,but fell like the car is in overdrive, no power. put car into low gear manually,and floor it it will take off, but still
not shiftin good.I got told the I.A.C. IS BAD. and the no # 2 injector is bad. will this fix this?? they want $600
to fix. am concern adout the tranny problem
thanks
Glenn
