Have the ignition module tested at most autoparts stores for free.
Most GM engines must have an ignition reference or the pump will shut off.
I would also remove and clean the EGR valve.
If you have access to a scanner, scan in live data mode, look at RPM. If, when it dies, you are getting erratic RPM readings, then ignition module would be primary suspect.
SPONSORED LINKS
Friday, September 4th, 2009 AT 6:20 AM
