I have a 1990 Pontiac Grand Am that will not run .It has 155000 miles on it. 2.5 TBI . It turns over . It gets spark , But no fuel . I changed the fuel pump ,changed the relay , I have also changed the ECM and it still will not run . It will run if I put gas in the carb . Fuel pump only runs when engine runs . Fuel is getting up to carb but not past the injector . Fuel injector does not work . No power . And the check engine light is not working . I did change the bulb . Still does not work ... I have gone over every thing I think and still can not find the cause of all the problems ... can someone help !! :?: [/b][color=darkblue:496128403e][/color:496128403e][b:496128403e][i:496128403e][/i:496128403e][/b:496128403e]
Aug 10, 2006 at 3:29 AM
