1989 Pontiac Grand Am fuel problem
JAMES A
  • 1989 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 196,000 MILES
I put a new fuel pump and filter in and car ran great for 24hrs. Now hard to start/stalls. Good fire on plugs. I have to use ether to get car to start.
Friday, June 20th, 2008 AT 6:52 AM
MMPRINCE4000
  • 8,548 POSTS
Check fuel pressure with a mechanical gauge. It is possible the strainer came off or the pulsator is leaking (if equipped), or the hose from pump to supply line is leaking.
Friday, June 20th, 2008 AT 7:06 AM
BMRFIXIT
  • 19,053 POSTS
Check fuel pressure
if low check and or replace the pulsator in the tank
(its the piece that the new pump connected to made of hard plastic and rubber )
Have an automotive repair question!
Sign up and ask your automotive question !
https://www.2carpros.com/affiliate/uid/bmrfixit_1_tlid_1
Friday, June 20th, 2008 AT 7:08 AM
