1987 Pontiac Grand Am WHERE IS?
70,156 MILES • 4 CYL • 2WD • AUTOMATIC
LAKEBASS
MUST BE BLIND; CAN'T FIND THE METER BOX THAT I BELIVE SHOULD BE UP FONT SOMEWHERE.
LOST BRAKES AND REPAIRED THE REAR LINES; BUT THEN THE LINES COMING DOWN THE FRAME WENT AFTER PUMPING UP TO BLEAD THEM.
HOPING TO JUST RUN NEW LINE FROM METER BLOCK TO THE REAR.
THANKS, JIM
Aug 5, 2008 at 9:47 AM
  • 75,988 POSTS
What meter box are you looking for could it be the combination valve if so just follow the brake line from the master cylinder it will lead you to it-If its the proportioning valve its at the back somewhere-
Aug 5, 2008 at 9:59 AM
