Door Ajar Warning stays on
DONELSO
I have a 2005 Pontiac G6 that the "Door Ajar" warning stays on all the time. All the door appear to be closing correctly and I check to make sure they are all closed. I do not see a sensor switch in the door jambs.
What shoudl I check? Where shoudl I look?
Apr 21, 2007 at 7:21 AM
PGSTMMM
[quote:a0f385b6a3="donelso"]I have a 2005 Pontiac G6 that the "Door Ajar" warning stays on all the time. All the door appear to be closing correctly and I check to make sure they are all closed. I do not see a sensor switch in the door jambs.
What shoudl I check? Where shoudl I look?[/quote:a0f385b6a3]
This happened to me on a Ford Taurus. It seems simple but worked, I cleaned the door latch. Dust can mess up the sensors. Hope this works for you
May 12, 2007 at 2:23 PM
