2008 Pontiac G6 Alarm and Door Ajar
2008 PONTIAC G6
CMARZ07
2008 Pontiac G6
My car is less than a year old, and recently when i lock my car the alarm will go off for no reason, also my door ajar alarm comes on even when all doors are closed. Are these related? Whats the fix. Took it to a dealer and they found nothing. So now I am forced to leave my car unlocked so the alarm does not go off. Thanks for your help.
Feb 25, 2009 at 12:54 AM
NICK E
I am having this same problem, which just began about three weeks ago. The door ajar warning comes on intermittently when I am driving and the interior lights illuminate after I've turned the car off and locked it. The alarm goes off without reason and I am becoming a nuisance to my neighbors, so if you have any feedback which may help me, please let me know. Thanks!
Mar 13, 2009 at 11:34 PM
BRIAN 1
  • 1,030 POSTS
follow this info,if the message comes on with all doors closed, that you open and close all doors individually to cycle the latch and switching mechanism. By doing this, you may allow the switch to close and affect the status of the message on the DIC. If you locate the door that keeps this message on with the door closed, remove the door panel and replace the door latch assembly.post back with what you find.
Mar 14, 2009 at 4:16 AM
KEZ1960
Brian,
Do you do the door closings individually with the car off, or key on, or car started? Thanks, for all your help.
Mark
Jan 24, 2013 at 8:23 AM
