2006 Pontiac G6 Water pump
12,000 MILES • 6 CYL • 4WD • AUTOMATIC
DONTLOOKBACK1961
I have the GTP 3.9l SFI engine and my water pump blew. Do I have to remove the strut and lower the wheel in order to get to the water pump? Is there anything else I would have to remove to get to the water pump?
Thank you
Apr 29, 2010 at 1:38 AM
BLUELIGHTNIN6
  • 16,542 POSTS
have to remove the air cleaner, intake manifold cover, engine mount strut. rotate the drive belt tensioner counterclockwise to release tensioner spring tension then remove the drive belt. after all is removed, this will give access to water pump.
Apr 29, 2010 at 6:10 PM
