Have to remove the air cleaner, intake manifold cover, engine mount strut. Rotate the drive belt tensioner counterclockwise to release tensioner spring tension then remove the drive belt. After all is removed, this will give access to water pump.
SPONSORED LINKS
Friday, April 30th, 2010 AT 1:10 AM
