2006 Pontiac G6 temperature
38,159 MILES • 4 CYL • FWD • AUTOMATIC
INGALI4
During cold or wet weather, the gauge inside the car drops (back to 100) and the cooling fans kick on. Yet when you take the positive cable off the battery for a few seconds and replace it then the gauge starts reading again and the fans shut off. I have replaced the temp sensor yet this problems is an ongoing thing.
Nov 17, 2009 at 9:45 AM
  • 110,248 POSTS
Have you checked the wiring to from the sensor to the PCM to make sure there are no brakes or damage?
Apr 19, 2010 at 3:55 PM
