2006 Pontiac G6 02 sensor or convertor?
2006 PONTIAC G6
42,000 MILES • 4 CYL • FWD • AUTOMATIC
RBSTAPLETON
I have the same problems described above with sluggish performance, hard to shift, high rpm and service engine light on. Code error is P0420 done at AutoZone with description of "catalyst efficiency low-bank 1". I'm suspecting most likely cause to be O2 sensor but not sure its a good idea to throw parts at it till I'm sure. Any suggestions?
Sep 21, 2009 at 11:58 AM
BRIAN 1
  • 1,030 POSTS
replace the catalytic converter.you can do an exhaust back pressure test to make sure,but a p0420 is usually a cat converter.
Sep 23, 2009 at 10:14 AM
