2006 Pontiac G6 02 sensor
2006 PONTIAC G6
99,200 MILES • 4 CYL • FWD • AUTOMATIC
CHUCKVDB84
i was wonderng how to replace te rear o2 sensor. if telocation of it is easy i can do it myself. just unsure of location and proper steps in replacing it
Nov 6, 2010 at 1:54 AM
BLUELIGHTNIN6
  • 16,542 POSTS
depends on engine size and which sensor and bank number but if it's a rear sensor it should be simple. just disconnect battery , raise vehicle and support safely. Locate sensor on exhaust system and disconnect its electrical connector. Use o2 sensor socket to remove sensor from exhaust system and then reverse steps to replace .
Nov 6, 2010 at 9:01 AM
