2008 Pontiac G5 Pontiac G5 No dash or tail lights
2008 PONTIAC G5
36,900 MILES • 4 CYL • FWD • AUTOMATIC
ITSMEMARKO
During the recent colder weather (10-20F) my dash lights and tail lights do not work. In a heated garage they worked... I checked the park lamp fuse and it was ok, but changed it just the same, as well as changing out a rear bulb, but no help.
Jan 2, 2010 at 9:27 AM
BMRFIXIT
  • 19,053 POSTS
Checking BCM for codes would be my 1st step
also check and suspect tail/park light relay in underhood fuse block
mark and switch relays
Jan 3, 2010 at 1:05 AM
