Radio and power window keep going off
PONTIAC FIREBIRD
KCHARRIER
I have a 97 Firebird with 118k miles, 3.8L engine. I bought the car with 84k miles.
From the day I bought it, every now and then the radio will go off while driving... when this happens the power windows will also quite working.
The symptom occurs more frequently when it is hot out, i.e. temperature related. However every now and again a good bump in the road will either cause it to either go off or come back on. It happens fairly regular and is not predictable. I have not been able to pin down any particular pattern when it will occur.
The firebirds have a delay module where you can still work the radio and windows after the engine has been turned off, after a period of time it automatically turns off the radio and stops the windows from working, or until you open the door. Is it possible it is this part that is malfunctioning?
Thanks for the help! :D
May 31, 2007 at 4:49 PM
KCHARRIER
There have been several reads but no responses... is it possible this is a unusual problem?
Jun 3, 2007 at 9:56 PM
2CARPRO JACK
  • 11,533 POSTS
Yes it is possible. They are both powered from the same fuse block inside the car. Look for anything tapped into the wiring ( alarm.. etc.) or anything out of norm might just be a bad connection
Jun 4, 2007 at 1:14 AM
