1988 Pontiac Firebird Rear Brakes Weak
Suggested Repair
Adjust the rear disc calipers. Remove the nut holding the parking-brake lever, use a 9/16 wrench to screw the piston in until it is only hand-snug and the wheel still turns, then reinstall the lever and tighten the nut. The cable and return spring may not need to be removed.
Conversation Summary
The owner of a 1988 Pontiac Firebird GTA with rear disc brakes and a posi rear said the rear brakes barely stopped the wheels with the engine running in drive, although they held with the engine off and the parking brake held. Fluid flowed freely from the bleeder and the calipers moved, with no air found in the lines. The expert said the rear calipers were out of adjustment and described tightening the pistons until hand-snug while the wheels still turn, then reinstalling the parking-brake levers.
