1978 Trans Am, Rebuilt engine and carb. new fuel pump, wires ohm out great, dist cap and rotor sufficent, timing on the mark as well as plug gap.
At full throttle enging stumbles as if low on fuel . let of the throttle it regains untill RPM range is met again. RPM is about 4500. Fuel float actually slightly jigher than spec.
Nov 8, 2007 at 7:35 AM
