coolant leak 1996 Firebird 3.8
JEEP03
  • 21 POSTS
I have a 1996 firebird 3.8. There is a coolant leak around the timing belt cover. Is this going to be a big job to fix it? Would a stop leak product work instead of trying to replace the gasket? Would appreciate any input, thanks
Mar 6, 2007 at 4:56 AM
MIKE H R
  • 3,094 POSTS
check to see if it is from a leaking hose or the water pump. pressure check the cooling system, that would tell where the leak is.
Mar 6, 2007 at 12:37 PM
JEEP03
  • 21 POSTS
[quote:24c9677fa5="JEEP03"]I have a 1996 firebird 3.8. There is a coolant leak around the timing belt cover. Is this going to be a big job to fix it? Would a stop leak product work instead of trying to replace the gasket? Would appreciate any input, thanks[/quote:24c9677fa5]
Thanks mj ritzel , I'll try that.
Mar 6, 2007 at 10:32 PM
JEEP03
  • 21 POSTS
[quote:4104e1d274="JEEP03"][quote:4104e1d274="JEEP03"]I have a 1996 firebird 3.8. There is a coolant leak around the timing belt cover. Is this going to be a big job to fix it? Would a stop leak product work instead of trying to replace the gasket? Would appreciate any input, thanks[/quote:4104e1d274]
Thanks mj ritzel , I'll try that.[/quote:4104e1d274]
It turned out to be the water pump ,thanks again for the advice
Mar 29, 2007 at 3:01 AM
