1997 Pontiac Firebird Clutch Slips
CRZTLE_22
i have a 97 pontaic firebird with 140000 mile. I replaced the clutch less than a year ago. Now it seems it is out again. It revs up when i press the gas but doesnt go like it should and when I am trying to go up a hill it acts like it wont make it. Can I just replace the plates of something?
Jan 8, 2007 at 9:57 AM
MMPRINCE3000
  • 133 POSTS
If the clutch is bad I would replace the disc, pressure plate, T/O bearing and have the flywheel resurfaced (if it can be).
Also check the output shaft seal to make sure it is not leaking oil as well as the rear main engine seal.
Jan 26, 2007 at 9:55 AM
Suggested Repair
If the clutch is bad, replace the disc, pressure plate, and throwout bearing, and resurface the flywheel if possible. Also check the transmission output shaft seal and rear main engine seal for oil leaks.
Conversation Summary
The owner of a 1997 Pontiac Firebird with 140,000 miles says the clutch was replaced less than a year ago, but the engine revs without proper acceleration, especially uphill, and asks whether only the plates can be replaced. The expert recommends replacing the disc, pressure plate, and throwout bearing, resurfacing the flywheel if possible, and checking the output shaft and rear main seals for oil leaks.
