2002 Pontiac Firebird Will not engage starter
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHELDONALLMAN
  • 6 POSTS
I have a new battery, all connections from the battery are good. When I turn the key on, all indicator lights come on, and when I turn the key to the start position, it will click in the control box one time under the hood. The starter does not do anything though.
Jan 12, 2010 at 1:02 AM
JDL
  • 16,098 POSTS
Welcome to the forum, does the theft/security lite, stay on or flashing, when trying to start? Next, I'd check the circuits at the starter relay in the underhood fuse box. Voltage the load side of relay, terminal 30, is hot all the time. Voltage to the coil side of relay, terminal 85, goes hot with the key in the start position. Use a dmm to check for voltage.
The pcm grounds the coil side of relay, if no ground, I'd have to double check the security system.
Some of the national brand autostores will test the starter. Yeah, you have to take it off and take it to them. I'd still have to be sure the battery has a full charge and the connections are good.
Jan 12, 2010 at 1:46 AM
SHELDONALLMAN
  • 6 POSTS
I did check the security light, but it seems to be working properly. I am going to check the other now. Is there a way to bypass the security system? Thanks for the info on the relays.
Jan 12, 2010 at 2:26 AM
JDL
  • 16,098 POSTS
If the security system is the problem, cranking the starter won't help. I can't help you bypass it.
Jan 12, 2010 at 4:14 AM
SHELDONALLMAN
  • 6 POSTS
I understand. I did check the battery, and it checked good. I went ahead and put a charge on it though. Thanks again for the info.
Jan 12, 2010 at 12:41 PM
SHELDONALLMAN
  • 6 POSTS
I have taken the starter off and had it tested. It was good. I show power coming in at the terminals on the silonoid, and main power cable from battery. After putting the starter back on, the car did crank two times with no hesitation. On the third try, it did the same thing, nothing??? after a few min. it cranked again. I changed the positive cable end it did have alot of corrosion. same thing. it cranks when it wants to.??
any more suggestions???
Jan 27, 2010 at 2:01 AM
JDL
  • 16,098 POSTS
When the starter refuses to crank, Is the purple wire at the starter solenoid, hot? You have to test when the problem is ongoing.
Jan 27, 2010 at 4:15 AM
SHELDONALLMAN
  • 6 POSTS
The purple wire is hot when the key is in the start position.
Jan 27, 2010 at 5:04 AM
JDL
  • 16,098 POSTS
If voltage and ground circuits are ok. The purple wire and the starter field terminal is hot, when the starter refuses to crank. Either someting is putting a load on the engine and starter, in that case, if you had the lites on, key in the start position, the lites would react if starter circuit from switch is closed. or the starter is faulty, don't care if you had it tested. Anymore the starter and solenoid is considered one unit. I guess I don't know how to help you, have a good day.
Jan 27, 2010 at 6:09 AM
SHELDONALLMAN
  • 6 POSTS
Thank you for all the input. I guess I will continue to look for the ghost. I will let you know when I find it.
Thanks Again,
Sheldon
Jan 27, 2010 at 12:39 PM
