2002 Pontiac Firebird Popping
22,000 MILES • V8 • 2WD • AUTOMATIC
IRONHORSE1969
I have this popping sound coming from the right rear wheel area. It happens when ever the right rear wheel (Only) passes over a pot hole or a speed bump. The car has new shocks and I've checked all bushings in the panhard, LCA, torque arm mounts, lugnuts, and bolts. The fluid is full in the differential so I'm now at a loss to figure out what is causing this?
Aug 22, 2009 at 1:10 PM
  • 110,248 POSTS
Does your car have rear struts? If so, check for a cracked or broken coil spring.
Sep 9, 2009 at 3:14 AM
