2002 Pontiac Firebird P 1125 Code
108,000 MILES • 6 CYL • 2WD • AUTOMATIC
FIREBIRDFAN
My 02 Firebird displays a P1125 code. What is it and how do I fix it. Are there multiple problems and/or solutions or is it a pretty straight forward problem with a straight forward solution?
Oct 7, 2008 at 4:39 PM
JROD123
[quote:393e52c982="FirebirdFan"]Engine Performance problem
2002 Pontiac Firebird 6 cyl Two Wheel Drive Automatic 108000 miles
My 02 Firebird displays a P1125 code. What is it and how do I fix it. Are there multiple problems and/or solutions or is it a pretty straight forward problem with a straight forward solution?[/quote:393e52c982]
Not good, that is an APP (accelerator pedal position) sensor malfunction. You can try to clear it and hope it doesn't come back, if that doesn't work. There are two paths. Salvage yard. Or go to the dealership, bend over and grab your ankles... the APP is nearly 500.00...
Jul 27, 2009 at 11:44 PM
