2001 Pontiac Firebird Cooling Fans do not stop running
2001 PONTIAC FIREBIRD
69,600 MILES • 6 CYL • 2WD • AUTOMATIC
LUISCARLOSALCALA
The cooling fans will not stop running. I have read that for air-conditioned cars, there is a fan controller but I do not know where to find it or what it looks like. I have check all the fuses and they work. There are three relays or boxed shape things in the fuse box, whenever I disconnect fan 1 and fan 2 the cooling fans stop working. I have been told to disconnect the wires to the cooling switch in the motor to check if there is a faulty connection. I have put the fuses or relays back where they are suppossed to be and the cooling fans still do not stop working.
Feb 3, 2010 at 4:53 AM
MERLIN2021
  • 17,250 POSTS
Test the relays...
http://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
Feb 3, 2010 at 4:57 AM
