2001 Pontiac Firebird car shuts down
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
BANK12
car shuts down when running..
whats the problem
Jan 12, 2009 at 4:16 PM
KEVIN12881
  • 336 POSTS
going to need more info than that...They make a 4 cylinder firebird? Have you kept up with maintenance? here are some things to check Engine lacks power... See one of the following: 1.) Incorrect ignition timing. 2) Fuel filter clogged and/of impurities in fuel 3) Faulty or incorrect gapped spark plugs. 4) Air filter dirty. 5) Spark timing control system not working properly. 6) Faulty ignition coil(s) 7) Brakes binding. 8) Auto Trans fluid not correct 9) faulty distributor cap or wires 10) EGR system not functioning properly. 11) Use of sub standard fuel. 12) Low or uneven cylinder compression pressures 13) Air vacuum leak at intake manifold or plenum ... most of those are for lack of power, but that could be the start.
Jan 16, 2009 at 12:05 PM
