2000 Pontiac Firebird Headlights
104,800 MILES • V8 • 2WD • MANUAL
DEREK55
Hi guys, i have been having problems with my low beam headlight on the passenger side. It burnt out on me once so i replaced it then the new one burnt out on me again. It is only this one headlight that has given me any trouble, the other ones are perfectly fine. I traced the wires back and all the connections look fine. Is it possible that may be to much power going to the one headlight? Or did i just happen to get unlucky and bought a faulty headlight? Thanks for your help.
Derek
Aug 12, 2009 at 4:02 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Check out ground at top of radiator support. Black wire see if connection is tight and clean.
Let me know
Thaks for donate
Aug 13, 2009 at 2:53 AM
