2000 Pontiac Firebird BACK UP LIGHTS
29,900 MILES • V8 • 2WD • MANUAL
CELESTE67
When I put my trans am in reverse the fuse breaks, i took the light bulbs out and it is still blowing a fuse. If it is the switch where is it located and how do you fix it?
Apr 19, 2008 at 5:33 AM
CORVETTECRAZY88
a main problem could be that the fuse is too low the amperage needs to be higher the problem arises when your lights are using more power than the fuse will allow try putting in a higher fuse that should fix the problem
Apr 25, 2008 at 1:38 AM
