1999 Pontiac Firebird Trouble Starting
1999 PONTIAC FIREBIRD
65,000 MILES • V8 • 2WD • AUTOMATIC
BIGREDSLED93
I have a 99 trans am and there are times it won't start. when i turn the key all the dash lights come on, but it won't turn over or start. there are other times it will turn over and try to fire then cut off. and sometimes it does just fine with no problems. i didn't have any trouble until a couple of weeks after installing a sub & amp with the power wire through the grommet in the firewall that has other wires through it. could there be some loose wires under the glove box?
Jul 25, 2008 at 2:32 AM
Test the ignition switch and recheck your hook up on the amplifier
Jul 25, 2008 at 6:20 AM
BIGREDSLED93
how do i test the ignition switch?
Jul 25, 2008 at 7:41 AM
