1999 Pontiac Firebird Front Turn Signals Will Not Blink
MAX9FLYER
Electrical problem
Hello, the rear turn signals work fine, but the fronts do not blink. They stay lit when I turn on the headlights, but other than that they do not blink at all. Turning on the hazard doesn't work for the front lights either, but the rears still work. I've replaced the turn signal flasher and front turn signal bulbs already and still no luck. The fuses look fine as well, please help thanks.
Jun 6, 2009 at 6:41 PM
KHLOW2008
  • 41,812 POSTS
Hi max9flyer,
Thank you for the donation.
Since rear turn signals are working, it should not be the fuses or the relays. The front turn signals goes into the Daytime Running Lamp control module and that should be the item you should be looking at.
It is located behind radio on left side of glove box.
Jun 7, 2009 at 4:08 AM
