1999 Pontiac Firebird 99 Trans Am Battery Charging Issue
66,000 MILES • V8 • 2WD • MANUAL
1999TRANSAM
Hello, I'm having a problem with my Battery charging on my 1999 Trans Am. The car will not charge the battery over 11.8 volts. I installed a new Optima Battery, Alternator, Battery Cables, and even a PCM (I was originally getting DTC P1638 Generator L-Terminal Wire). With the car running, I am measureing 14.4 volts at the battery but for some reason it will not charge above 11.8 volts. When I connect a home charger, it will charge to 12.66 volts. I've been trying to diagnose this problem for about a year now so any help would be greatly appreciated.
Thank you in advance!
Jason
Sep 30, 2008 at 1:48 PM
KHLOW2008
  • 41,812 POSTS
Hi Jason,
Thank you for the donation.
I don't understand your question fully.
When engine is running, voltage is 14.4 v at battery? When does it become 11.8 v?
Did you test charging voltage after running for 1/2 an hour?
Oct 1, 2008 at 1:34 AM
