1998 Pontiac Firebird Turning Signals
102,000 MILES • 6 CYL • 2WD • MANUAL
SCRABSTAR
My turning signal bulbs are lit, but they stopped blinking in the dash display and outside the car in both directions.
I checked the fuse, in the main fuse box by the drivers side door, and it looked ok to me. What else could the problem be? Is there a relay or something that could have failed?
Jan 8, 2010 at 12:58 PM
  • 75,988 POSTS
Check and test the turn signal flasher and the turn and hazard switch
Jan 8, 2010 at 1:00 PM
SCRABSTAR
Ok, so the Hazard lights still work, I switched the fuse from the Hazard spot to the Turning signal spot and still nothing. Any ideas?
Jan 8, 2010 at 1:13 PM
  • 75,988 POSTS
Test the turn and hazard switch everything goes thru there then to the back lights
Jan 8, 2010 at 3:48 PM
SCRABSTAR
You mean the actual turn lever attached to the steering column, I'm assuming. What is the best way to test it? Do I need to take the wheel off to do this?
Jan 10, 2010 at 7:24 AM
  • 75,988 POSTS
Did you check the turn signal flasher? If okay you need to remove the s/wheel and trace the wires the turn signal wires Left sig is the light blue wire, Right sig is the dark blue wire-
Jan 10, 2010 at 8:06 AM
