1998 Pontiac Firebird Speedometer
130,000 MILES • V8 • 2WD • AUTOMATIC
WARD MENSMAN
Hello, my speedometer is not correct for the speed that is being driven. The faster i drive the more its off. I have had the speed sensor replaced and its the same. What do i need to have changed.
Feb 11, 2009 at 7:36 AM
TEAG
  • 158 POSTS
Try checking your speedomter cable. To do this you need to get under the car by the transmission. Youll see the cable running into the tranny right behind the tranny mount on the drivers side. Disconnect it and seed if you can spin the cable inside the sheath. It should move fairly easy. If not, you may have a bad cable which could cause a false speed reading. If it is bad.........before replacing......Id spray the inner cable with some wd-40 and see if it loosens it up. If not, it needs to be replaced. Good luck :)
Feb 22, 2009 at 9:38 PM
