1998 Pontiac Firebird No power
ONETIMEJRR
1998 Pontiac Firebird 6 cyl Manual
Can't get above 20-25 mph...have replaced spark plugs. No idea what to check next.
Jul 18, 2010 at 11:24 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 18, 2010 at 11:42 AM
