1998 Pontiac Firebird fuel pump
1998 PONTIAC FIREBIRD
115,000 MILES • V8 • 2WD • AUTOMATIC
BETOVEN37
does the 98 trans am have a fuel pump reset button or when u can't hear the pump i need to replace the pump ?my son ran out of gas and i started it and then it turn off then i could not turn it on >and can't hear the pump anymore
Jan 14, 2009 at 5:32 AM
BMRFIXIT
  • 19,053 POSTS
No reset for the fuel pump
add gas check fuses and fuel pump relay
suspect fuel pump inside the tank
try to hit the mid of fuel tank as a helper trying to start some time that will get you going so you can take it home or to a shop
good luck
Jan 14, 2009 at 5:37 AM
