1997 Pontiac Firebird Radio/Power Window problem
10,500 MILES • V8 • 2WD • AUTOMATIC
IGODOU
Without warning the radio, clock and power windows quit working. This is while the car is running. Absolutely clueless as to where to begin. As far as I can tell, no other problems like remote entry or wipers etc quitting. Thanks.
Dec 5, 2008 at 10:26 AM
CMCC
Do they work intermittently, or are they just dead now?
If they're just dead, you can check the fuses.
Jan 26, 2009 at 9:48 AM
ANIM8OR
This happened on my 2001 Firebird. The problem is bad solder on a component called a Body Control Module, located under the glove compartment, near the kick plate. Takes about 2 hours to fix. Here's a link that details everything....
http://www.camarozone.com/how-to-fix-intermittent-windows-radio-and-locks/
Jul 9, 2012 at 8:12 AM
