1997 Pontiac Firebird My car has no heat
1997 PONTIAC FIREBIRD
98,000 MILES • V8 • 2WD • MANUAL
AIMEE0220
I replaced the thermostat in the car, coolant level is ok, there are no leaks of coolant anywhere. I have no heat at all though in the car. The guage is at normal operating temperature and the ac works fine.
Jan 19, 2008 at 5:29 AM
BMRFIXIT
  • 19,053 POSTS
[quote:b39e053e56="aimee0220"]Heater problem
1997 Pontiac Firebird V8 Two Wheel Drive Manual 98000 miles
I replaced the thermostat in the car, coolant level is ok, there are no leaks of coolant anywhere. I have no heat at all though in the car. The guage is at normal operating temperature and the ac works fine.[/quote:b39e053e56]
make sure the blend door working
check heater core hoses they should be hot both if not you need to isolate the heater core and flush it
good luck
let me know
Jan 19, 2008 at 6:04 AM
