1997 Pontiac Firebird 6 cyl Two Wheel Drive Automatic
my key won't turn in the ignition
Oct 28, 2008 at 5:25 PM
BLUELIGHTNIN6
✓Experienced Mechanic
Wiggle your steering wheel around while you try to turn the key. If that doesn't help, your key could be worn or slightly bent and needing replaced. Post your results and I will follow up.
