1997 Pontiac Firebird Gear shift stuck!
133,000 MILES • 6 CYL • 2WD • AUTOMATIC
BONREP67
off and on for the past couple of months gets stuck in park, but eventually gear shift releases, but not today. tried every trick to get it into gear, but no luck. usually a good swift kick will work, but not today.
Feb 8, 2009 at 11:09 PM
MIKE H R
  • 3,094 POSTS
the shift lock could be bad. there is a way to get it out of park. you need a small straight metal wire. on the top right of the shifter there is a safety release. when you push it down it will bypass the shift lock.
Feb 13, 2009 at 12:22 AM
