1997 Pontiac Firebird fuel injectors
ARMYBAT2000
Engine Performance problem
1997 Pontiac Firebird 6 cyl Two Wheel Drive Automatic
how do you replace fuel injectors on 1997 pontiac firebird 3.8
Mar 1, 2009 at 3:21 AM
TEAG
  • 158 POSTS
You have to remove the fuel intake manifold to get to the fuel rail........ Once you have that off theres only a few bolts holding the fuel rail in. remove the bolts, unplug the fuel rail, disconnect fuel lines and pop out the injectors. Good Luck :)
Mar 24, 2009 at 1:34 PM
