1997 Pontiac Firebird Convertable Top
98,500 MILES • 6 CYL • 2WD • MANUAL
GASWADMIKEY
My daughter just purchased a 1997 Firebird convertable. The problem is with the power top. When you push the switch you can hear the sound of the pump motor running, but the top will not move up or down. The top can be manually be put up and down, so it isn't binding. We purchased a Haynes manual, but it does't address the power top. Any ideas where to start looking? It was working fine, then just quit. Thanks!
Apr 21, 2008 at 10:13 AM
CORVETTECRAZY88
try checking the linkage for the motor if it is not in sync the motor will not drop down you can find the diagrams online for the linkage through goodle or some other search engine
Apr 25, 2008 at 1:45 AM
